OctaneRender® for 3ds max® v2021.1 RC2 - 12.04
paride4331
Sidches wrote:Hey Paride, yep, I will try to make a test project with this problem.
Found more bugs:
• invisible light casts shadows!
• big problem with batch render, all render passes saves in one folder and even overwrites, all the sequences are mixed.
Only beauty passes are saved in separate folders.
• The old version(2020.2.5) renders twice as fast.
Hi sidches,
is this the invisible light cast shadow issue you reported?
viewtopic.php?f=80&t=78491&p=404916#p404916
Regards
Paride
Sidches
Paride, yes it is.
But the rtx is a separate problem.
paride4331
Found more bugs:
Hi sidches,
I can't replicate your batch render issue, could you give me more info about your workflow?
Regards
Paride
Sidches
I solved my butch render problem! Thx =)
paride4331
Sidches wrote:Paride, yes it is.
Hi Sidches,
about the RTX issue, it seems to depend on meshsmooth modifier.
I think RTX highlights some geometry issues.
Here's a link that I hope it can helps you.
https://forums.autodesk.com/t5/3ds-max- ... -p/7880084
Regards
Paride
Sidches
Hey Paride, I sent you a scene with rtx problem in private messages.
paride4331
Sidches wrote:Hey Paride, I sent you a scene with rtx problem in private messages.
Hi Sidches,
Yes, I tested it; it seems to depend on meshsmooth modifier.
Regards
Paride
