OctaneRender® for 3ds max® v2020.2.1 - 11.07, 3dsMax2022
@ Paride : Yes, my fault (again)
But it seems that I'm in a very bad mood these times... I misunderstood that I can revert to old behavior, I thought at a toogle...
@anifex3D : It seems that there is a hang because the installer is scanning hd for installed max versions.
- neonZorglub
Hi HHBomb,HHbomb wrote:Hi,
Added support for tyFlow particle Age. If you have a file to share I'll be happy. I can't manage to make it works.
I added a sample to the tyFlow post :
viewtopic.php?f=27&t=73516#p398609
I get this connection error since a few versions now. Even with scenes containing one surface only. Render stops with GPU error. Using the latest studio drives.
What's up there?
What's up there?
OctaneRender Enterprise 2020.2.1 (10021301)
Can't connect node 'oDiff_07 - Default' (NT_MAT_DIFFUSE, 00000234577DBBD0) to static pin 'layer' (P_LAYER, type PT_MATERIAL_LAYER) of node 'Universal material' (NT_MAT_UNIVERSAL, 0000023415C6A8B0)PURE3D Visualisierungen
CUDA Error on a very small scene. Happens from time to time. Whole driver crashes and I need to restart 3dsmax.
Failed to create CUDA context
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 1: unspecified launch failure
-> failed to download symbol(stats data)
device 0: path tracing kernel failed
device 1: path tracing kernel failed
CUDA_ERROR_LAUNCH_FAILED: unspecified launch failure
denoiserThread0 : Exited with a error. Restart required
denoiserThread1 : Initialization failed. Restart required
-> failed to destroy CUDA event
-> failed to destroy CUDA eventPURE3D Visualisierungen
- neonZorglub
Hi mbetke,mbetke wrote:CUDA Error on a very small scene. Happens from time to time. Whole driver crashes and I need to restart 3dsmax.
Failed to create CUDA context CUDA error 719 on device 0: unspecified launch failure CUDA error 719 on device 1: unspecified launch failure -> failed to download symbol(stats data) -> failed to download symbol(stats data) device 0: path tracing kernel failed device 1: path tracing kernel failed CUDA_ERROR_LAUNCH_FAILED: unspecified launch failure denoiserThread0 : Exited with a error. Restart required denoiserThread1 : Initialization failed. Restart required CUDA error 719 on device 0: unspecified launch failure CUDA error 719 on device 1: unspecified launch failure -> failed to destroy CUDA event -> failed to destroy CUDA event CUDA error 719 on device 0: unspecified launch failure CUDA error 719 on device 1: unspecified launch failure -> failed to destroy CUDA event -> failed to destroy CUDA event
Could you provide this small scene ?
I've sent you a PM with the link.
Used Universal Camera the first time and got a bunch of error while playing with the settings.
Even a GPU Error and ender stop.
Started logging on 31.03.21 08:28:08
Empty file name.
Empty file name.
Can't connect node 'tx-Map #10' (NT_TRANSFORM_2D, 000002A41C0453F0) to static pin 'bump' (P_BUMP, type PT_TEXTURE) of node 'mtl-Leika2' (NT_MAT_UNIVERSAL, 000002A42E957580)
Empty file name.
Empty file name.
<nodes>:26: error: No matching function call to 'evaluateTileGrid (color, string, float, float, int, int, int)'
Candidates are:
void evaluateTileGrid (color, string[], float, float, int, int, int)
We generated invalid OSL code
Candidates are:
Failed to compile OSL shader.
Candidates are:
Candidates are:
Empty file name.
Empty file name.
