juanjgon wrote:Mastoy wrote:No dirt node in the scene
I made a few tests :
- With standalone scene renders fine on master PC
- With standalone scene renders fine on slave PC
- With standalone on master PC, and network daemon on slave, slaves crashes instantly
Do you have this problem with all your scenes? If not, could be great to get the .orbx file of the scene with this problem to try to reproduce it here.
It happens with all of my scenes, but It seems to be either an object issue, or a surface issue :
I have made some tests and I've narrowed the problem down to a simple LW scene where :
- If you start the IPR, the network rendering works
- Add one of my objects, start the IPR, and the slave deamon crashes as soon as the scene is sent through the network (Cuda error 700 apparently)
- Delete this object, start the IPR, network rendering works !
So it seems that my LW objects crash the 2020 slave deamon (it works fine with version 2019)
I can send you all of these elements via mail, as my objects are property of my clients. Is it ok Juanjo ?
Thx !
