Octane 2020 For Unreal Engine - v0.32: Geometry Cache
Moderator: ChrisHekman
Notiusweb
Hi Chris, I am going to send you link for a test project.
It looks like Octane .33 has issue with opacity textures on characters run through UE4.
(It has been the case since first release, but this project will be for 4.24.3).
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
gillmediastudio
Greetings Chris!
This is Gill Media Studio. We are working of a hyper realistic CGI feature film inside unreal engine and we have purchased the enterprise edition of the standalone renderer and we are currently facing some issues.
Kindly look into the following!
We tested out the latest v0.33 release (Which actually is 0.32 for some reason) for UE. The camera and sequencer seems to be working fine, But the skeleton mesh with morph targets are disappearing from the render which wasn't the issue with some of the previous version (except the camera issue) like in v0.28. Is there a way to fix this?This is the biggest hurdle we are facing with the Renderer as our whole movie has facial performance capture driven by morph targets only.Kindly, Look into it on an urgent basis!
We'd like to collaborate on this project with you if possible and planning to buy upto 20 more license for production purposes!
This is the link to the teaser of our upcoming feature:
https://www.youtube.com/watch?v=xUhZHpGlYLo
We believe could be sky rocketed using your renderer only if the above mentioned problem is solved
Thank You!Looking forward to hearing from you.
natemac00
Any update on baking the Octane lights & materials to use in packaged usable file?
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
ChrisHekman
gillmediastudio wrote:Greetings Chris!
I will look into this. And try to come with a new build somewhere around the end of this week.
In the meantime, there should be a plugin setting that forces the use of CPU skinning. You can try turning that on and see what happens.
ChrisHekman
natemac00 wrote:Any update on baking the Octane lights & materials to use in packaged usable file?
Lightmapping similar to unreals lightmapping system is in the works. The results of which should be usable without the plugin.
Is this what you mean?
ingmannori
Hi guys,
I'm new to Octane for Unreal so I'm sorry if I'm asking for something stupid.
I just installed Unreal 4.24.3 from Epic Launcher and then I installed the latest OCT plugin "OctanePrime0_32_UE4_24.exe".
When launching the plugin I get a warning message "This build is not supported anymore. Please update to a newer version".
What am I doing wrong?
I also put cudnn64_7.dll in the right path...
Thank you in advance for any hints.
Andrea
StyleMarshal
Hey Andrea , you also need the newest Standalone , you can download it here :
viewtopic.php?f=33&t=74419
btw . the newest Unreal Plugin is 0.33 :-)
ingmannori
Thank you for the quick reply.
It seems that I'm not authorized to open the link...
ChrisHekman
ingmannori wrote:Thank you for the quick reply.
0.32 is an outdated build.
Here is the latest build: viewtopic.php?f=132&t=74177
