OctaneRender™ 2019.1.2
Jolbertoquini
Silverwing wrote:Hi there to the Developers of Octane.
First of thanks a lot for all the time ans effort you pit in the steady development and making Octane better.
I am hoping to catch your attention just for a moment:
Upon testing the Universal Camera I compiled a list of (for me) essential features, and nice to haves:
Essential:
Please change the Aperture Texture be read at least gray-scale data (right now its binary either black or white). Color would be even better.
This is limiting in many ways as: Not being able to bring the subtleties that a lot of lenses have into the bokeh.
With color there is the possibility to simulate lens chromatic aberration by using bokeh maps like this:
Subtle Variations that a Bokeh map has that makes the render look infinitely more realistic:
Bokeh for generating a lens chromatic aberration effect:
Essential:
Being able to control the other aperture settings simultaneously to an Aperture Texture
Right now using an Aperture Texture disables Aperture Edge, Bokeh Side Count Bokeh roundness and all the other features.
So for example right now its impossible to have a Aperture Texture with a bokeh that has some uneven brightness contribution (Aperture Edge) since the texture is read in as binary black and white (not able to produce gradients) I can´t either set it inside the map nor can I set it in the Aperture Edge settings since it wont let me use those together with an Aperture Image.
Nice to have:
Lens Bokeh Cateye Effect (of course including using all the other effects combined with it)
Nice to have:
Dedicated lens chromatic aberration slider (That just splits your bokeh into colors so you get some aberration)
Nice to have:
When being able to use grayscale / color images inside the Aperture Map setting, rendering can get darker. Therefore a lot of render-engines that allow for Aperture Map use have brightness compensation built in, so your renderings brightness is not depended on the brightness level of your map[/list][/list].
I hope some of the changes could be implemented into 2019.1.x already. Or later in 2019.2
Thanks for your attention!
Raphael
I'm totally agree +1000 on this, right now I don't know if the lack of information about how to use "the aperture texture" feature, but is completely pointless doesn't change the bokeh and just give a mask black when use RGB ( I guess this all the point ) and use alpha image also doesn't change the bokeh? I look around and nothing on the "Manual" how to use, basically the Lua camera script from Lightwave section "texture aperture cam.osl" way better results and at least we get the bokeh modified.
Maybe is just me... but this case please update the Manual with some more information. would be great. Anybody there manage to make work on the end?
JO
PS. UPDATE
I realised with "OSL Delayed UV" is working but is not the defaut projection mode :( ... I guess need to be comment on the "Manual" would be helpful about it, and yes agree be able to add color bokeh would be amazing! :) Cheers
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
vijay
J.C wrote:Hello, thank you for the new release!
Can you tell us if shading errors with Vertex displacement (Auto bump) and Rounded edges will be fixed? They still exist in this release.
Hi, I'm currently looking into vertex displacement Auto bump map issue. Thanks
funk
I have found a couple of issues with autobump too.
1. It removes any existing bump map. It should be mixed with any bumped map plugged into the bump pin
2. Sometimes the autobump effect is too strong. I would like to see an "autobump amount" pin, so we can reduce the amount of bump.
pegot
funk wrote:Sometimes the autobump effect is too strong. I would like to see an "autobump amount" pin, so we can reduce the amount of bump.
+1
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
vijay
funk wrote:I have found a couple of issues with autobump too.
I'll look into this. Thanks
Jolbertoquini
Hi Guys,
Me again about the same thing cause I didn't had any reply or help to understand the reasons behind if is a Maya Plug issue or a Standalone about Alembic instances?
The strange thing is Octane 3.06 works and other Octane not which makes the file huge cause doesn't recognize the instances as scatter nodes the file scene and the breakdown problem description is on the link here:
viewtopic.php?f=33&t=71853&p=365558#p365558
Can somebody give us a light and a reply about it? the same issue on this version.
Regards,
JO
J.C
haze wrote:
J.C wrote:Clouds has intersecting issues when "Emulate old volume" is enabled.
The legacy volume rendering had issues like this, which is why we fixed it. To avoid breaking older scenes, we kept the option there so that existing scenes that may or may not rely on that behaviour don't get broken. For newer scenes please leave the emulate option disabled.
The legacy rendering still differs in 2019 compared to 2018.
System – Windows 11
linograndiotoy
Hi Vijay!
I've noticed that Vertex Displacement doesn't work with Geometric Primitives anymore in 2019.1.2. When imported geometry is used, there are no issues.
Thanks!
haze
Thanks, fixed in next release.
abstrax
Zay wrote:Updated my slave PC to this version but when I start it, it shuts down immediately. Does the slave work on Win 7 ?
I just tried it here on my computer (Win 7) and the slave as well as the daemon work fine.
