Curves and Cd in Octane 2018 not working
Houdini Integrated Plugin
fantome
i forgot to post the code you need to put inside a Primitive Wrangle to export @Cd and @Alpha by using @uv.
you are able to export them inside your .abc. and use rgb and alpha .ppm map directly.
int base       = 64;
int resolution = 4096;
float r = @Cd.x;
float g = @Cd.y;
float b = @Cd.z;
float a = @Alpha;
float min = 0.04;
float max = 0.96;
if(r<min) r = min; if(r>max) r = max;
if(g<min) g = min; if(g>max) g = max;
if(b<min) b = min; if(b>max) b = max;
if(a<min) a = min; if(a>max) a = max;
int rl = r*(base-1);
int gl = g*(base-1);
int bl = b*(base-1);
int al = a*(base-1);
int rgbLine = al + bl*base + gl*base*base + rl*base*base*base;
int xPix    = rgbLine%resolution;
int yPix    = rgbLine/resolution;
[email protected] = (float)xPix/resolution;
[email protected] = 1.0 - (float)yPix/resolution;
it work for curves in standalone
it doesn't work on point due to abc importer restriction
Return to “Houdini”
