Nope, only version 2019 and up.RSC wrote:Any updates if Octane v4 will still be implemented in Blender 2.8?
Question about OC for Blender 2.8
System – Windows 11
System – Windows 11
viewtopic.php?f=32&t=68774&start=20linograndiotoy wrote:Octane 2018/2019 for Blender 2.8 will be released first, with V4 following closely.jerzy wrote:Thanks for the reply.
Bit off topic. Will there be a version of V4 for Blender 2.8 once released or will current V4 users have to sign-up for subscription to continue to use Octane with contemporary versions of Blender?
I had asked this question in another discussion and I was told at that time V4 was going to be released but after 2018/19. Has that plan changed?
- linograndiotoy
No, I don't think that's changed.jerzy wrote:viewtopic.php?f=32&t=68774&start=20linograndiotoy wrote:Octane 2018/2019 for Blender 2.8 will be released first, with V4 following closely.jerzy wrote:Thanks for the reply.
There will not be Octane 4 for Blender 2.8 "free tier" for sure, because that would not make any sense.
I'll investigate and give you a more definitive answer soon!
Hi Lino! First congratulations on the new Octane for Blender version, it is awesome!
I wanted to ask will there be any news for the subscription version?
Also when will you integrate the stable 2.8 and will livedb, hair and motion blur be fixed?
And one or two off questions since I'm coming from C4D: does the blender version use the particle system instead of Octane scatter for distribution of objects?
About lights, isn't there also light options as in C4D when you put tags on a regular light, i can't seem to find those parameters and octane is not supporting the native spot, area, etc..
Sorry i am bothering but until the documentation is updated there are some things i am missing that i am used to while working in C4D.
Any info is welcomed and thank you!
Octane plugin uses Blender particle system (emitter and hair) or dupliverts as scatter solution. Both have cons and pros. I mostly use particle system (hair) to scatter objects which feel the most flexible for me.ivobran wrote:
About lights, Blender plugin uses meshes as light emitters. You have to create diffuse material with emission to create a light.
You can also use Blender's area light but you have to manually add material with emission. In 2.8 it is done automatically. Spot light has to be done using texture connected to distribution input and perspective projection.
System – Windows 11
System – Windows 11
Thanks J.C!J.C wrote: Octane plugin uses Blender particle system (emitter and hair) or dupliverts as scatter solution. Both have cons and pros. I mostly use particle system (hair) to scatter objects which feel the most flexible for me.
I already figured it out for Spot and IES lights although it woild have been nice to have octane support for the native blender lights. For the particle system i just starting playing with it. All i am missing is just Live and LocalDB so i can import my library..
