XParticle motion blur/ increasing render times
Please make sure to have updated c4doctane to v2020.1.3-R2.
You need to select your purchased version from the Select Software pop up:
Motion Blur seems to work correctly with latest XP update here:
ciao Beppe
dasmodular
Hello,
the problem still persists!
Please have a look into the attached scene file, the Octane log file and the screenshots.
In the scene file there is an emitter with a kill modifier, so that after frame 8 the particle count is constant at 29000.
Caching the particles does not make a difference.
Geometrie Control is set to All Objects Movable.
Please have a look into this issue!
Best regards,
Denis
C4D R25.010
Octane 2020.2.5-R3
X-Particles Build 1036
Windows 10 64-bit
Asus Geforce RTX 2080 Ti
X-Particles Motionblur C4D.zip
(146.56 KiB) Downloaded 267 times
octane 2020.2.5 210928 122513.log
(28.62 KiB) Downloaded 244 times
please try to set the XP Cache to Basic, rebuild it, and report back, thanks:
ciao Beppe
dasmodular
Hi Beppe,
setting the xpCache to basic does not make a difference:
motionCnt and mblurTM is still increasing at the same particle count per frame.
Best regards,
Denis
log.txt
(26.75 KiB) Downloaded 246 times
young.r85
Hi all,
We're having this same issue. Using Motion Blur and XParticles makes every frame increase in render time. Our work around is manually rendering 10 frames at a time. Not ideal.
Octane 2020.2.5 with C4D 24
Anyone have a better work around?
Cheers!
Ronny
Using a Kill object will not cause having less IDs are stored to define motion data in current algorithms. Increase on stored IDs that are causing bigger and bigger preparation times for motion data. Only way is to use more CPU threads in cameratag/motion_blur. See my picture for parameters and results. But increase over time undeniable with current versions.
Anyway I'm checking to improve it for this case.
KeeWe
Ahmet, just a quick question: is a value of 0 for used CPU Threads not utilizing ALL available cores? I always thought 0 means "go with all you have" and typing in a number is only to limit how many threads are used.
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
KeeWe wrote:Ahmet, just a quick question: is a value of 0 for used CPU Threads not utilizing ALL available cores? I always thought 0 means "go with all you have" and typing in a number is only to limit how many threads are used.
Checking that but I might be wrong because related part seems disabled for the builds. I'll give info for updates
Here's my results with a test build, I'm using 16cores cpu
KeeWe
Would there be any downside of setting the core count to the max available, even if not working with XPparticles?
