Octane 4 transplating keyframes onto wrong objects
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
boxfx
That's tricky right now. The problem only shows up when a significant chunk of the project has already been rendering. ie. if I select the broken frames to render, they will render fine. Only when previous frames have been included in the render process does it go wrong. I've tried to make a cut down scene to show it, but i'm crashing out often when the render gets to the frames where the problem shows up. The best I can do is send the entire heavy project, but you'll need to render from the frames set for the problem to happen.
Whats the best way to send over a confidential project? I can't post it publicly here.
Understand! You can send by Pm in forum. I don't need texture's.
boxfx
All fixed in 4.0.1 thanks
Return to “Bug Reports”
