OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.15 RC5
hkleton
Yes, same here, first render you do is black.
Render same frame again, and it is normal.
BorderLine
Same here !
pixym
I will send the scene asap. Octane aborts render after a few frames, about 40th. The abordting does not finish, so I have to End Lightwave then relaunch it.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
pixym
This is the attached packed scene, the log file is also included.
Pixym_Pack.zip
(412.77 KiB) Downloaded 251 times
juanjgon
hkleton wrote:Yes, same here, first render you do is black.
Sorry for this issue. Somehow the Octane API function used to get the image data fails for the first rendered frame. We are investigating what could be the problem.
juanjgon
pixym wrote:This is the attached packed scene, the log file is also included.
Thanks for the scene. Yes, it seems some kind of issue with the denoiser, that fails reporting a message "denoiserThread0 : Initialization failed. Restart required". I'll try to report this issue to the core devs to see how it could be fixed.
juanjgon
You have the rendering mode configured to full scene reload. Can you please try to render the scene again in update mode to see if it helps?
pixym
Hi Juanjo,
I will try that once I will be in my office and let you know if the issue still happens.
pixym
Juanjo,
I have tried with both of these settings :
1 - Full scene reload = Render Failure at frame 42
2 - Update scene = No issue at all
Best.
alperocak
Hi Juanjo.
I'm getting this error.
https://drive.google.com/open?id=1wQyo4 ... 8ux_3YNw5R
I'm using win7 64bit and LW 11.6.3 64 bit.
I'm trying to install from this folder.
https://drive.google.com/open?id=1quxE5 ... FLGPkojRlG
Thanks in advance.
Return to “Lightwave 3D”
