Spectral or RGB has nothing to do with any of the utility maps, only color calculations. 50% opacity is 50%. It's simple math. Displacement is internally hard coded to gamma 1.0. And, for all the same reasons, every map other than diffuse should be set to 1.0 as default. If people want to adjust it later, fine. But, the correct default for all utility maps is gamma 1.0.paride4331 wrote:Hi senorpablo,
put my two cents in, Octane is spectral not rgb, but unless you only work with 16bit and 32bit files and have HRD monitors, set everything to gamma 1 there's not much sense to.
I personally consider gamma editing in a more creative way, adjusting it in the textures according to the needs; except for hdri files.
normal as displacement works indifferently with gamma 1 or 2.2
Regards
Paride
Please discuss this with a programmer who perhaps can convince you better than I.
The fact that there's even a gamma spinner in the displacement map(that does nothing at all) is misleading.
