Bifrost
TDZL
Arnold GPU is on the way and that works with everythiing Maya. Please sort it out, Octane is literally starting to limit what I am able to create. :(
With the whole VDB thing, I don't see why it's necessary? I don't want to export / import my particles. Basically I used Arnold before and it just did what it was told.
BK
TDZL wrote:Arnold GPU is on the way and that works with everythiing Maya. Please sort it out, Octane is literally starting to limit what I am able to create. :(
Hi TDZL,
Agree !! We will do our best to get this sorted ASAP.
By the way, the Maya particle would also work with Octane when it's converted as Polygons and no need to export as VDB.
Cheers
Kind Regards
bk3d
calus
TDZL wrote:any way to have Octane render particles natively in maya ?
You can render particles as octane primitives trough ORBX proxy in Maya :
- Select particle shape, cache selected as alembic (Maya builtin), create an ORBX proxy node, open the EDIT UI, import the ABC cache, edit particle size in the node setting,
and don't forget to close the ORBX proy EDIT UI to validate the changes.
Pascal ANDRE
BK
Thank you Calus..
Kind Regards
bk3d
TDZL
Ok, so still having some problems with the above method.
- I can't preview my Bifrost Aero simulation before caching.
- After I have cached the simulation (Which can only be cached as a mesh), loaded the abc cache into the EDIT UI , Maya has a fatal error and CTD upon closing the EDIT UI.
Any more information would be awesome.
calus
TDZL wrote:Ok, so still having some problems with the above method.
Right the above method was to render maya nParticles to octane sphere primitive, it's not applicable to Bifrost.
Maya 2019 will bring builtin VDB caching for Bifrost so should make foam and Aero possible to render with Octane even if the plugin still doesn't support bifrost API.
Pascal ANDRE
TDZL
Ah damn, so how does Arnold mange to do it, what's the difference?
Again I don't see why the VDB thing is necessary?
I remember seeing videos from this dude that had figured it out. soup-dev.com
But back to the original question, when will Octane support Bifrost?
A work around that will be available at some point in the future is not really that great of an answer... :(
calus
TDZL wrote: A work around that will be available at some point in the future is not really that great of an answer... :(
Right, but Maya plugin development is so slow I'm resigned to rely on workarounds for almost everything to avoid bugs and solve missing or half implemented features.
At least now workarounds are way easier thanks to the ORBX Proxy node.
Pascal ANDRE
TDZL
Thanks for all the info Calus, will defiantly be looking into the ORBX Proxy node.
I don't think Maya is a priority and I feel is as a user. I guess Octane is no longer the best tool for the job and it's time to start integrating back into Arnold.
To the team, this topic was stared in August and nothing has changed.
BK
TDZL wrote:Thanks for all the info Calus, will defiantly be looking into the ORBX Proxy node.
Hi TDZL,
My apology for the late reply, as we have already discussed Bifrost is in our high priority to support.
New features can be implemented one at a time so we don't break our plugin. So the tickets are in the queue.
As a quick update, the Bifrost priority is set as 2nd highest.
Thank you!!
Kind Regards
bk3d
Return to “Autodesk Maya”
