OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.9 XB4
juanjgon
BorderLine wrote:Hi and thanks JuanJo,
There is a crash problem with network rendering ! First F9 render is OK but crashing in second F9 in the same scene.
Desactivate Network and it's OK !
Too bad because denoising with 6 Titan X, it's just perfect!
Franck
What crashes, LightWave or the render node? Be aware that some features like the AI lights are not supported yet by the network rendering. Can you enable the log file to see if there is any error message on it?
BorderLine
Lightwave crash !
Lightwave crash and after my 3 screens become black and i must reset my PC !
Log file attached !
OCTANE_NETWORK_PB.txt
(263.46 KiB) Downloaded 335 times
nico_cad
here works fine!!! thanks Juanjo!!! you are a great men with a big mind!!! :)
for use th last final plugin and standalone whats release need instal?
BorderLine
nico_cad wrote:here works fine!!! thanks Juanjo!!! you are a great men with a big mind!!! :)
No problem with render network Nico ?
DarkMoon
Nice! THNX!
BorderLine
BorderLine wrote:Lightwave crash !
Log file attached !
Hi JuanJo,
Any news for network rendering problem?
juanjgon
Log file attached !
Hi JuanJo,
Nope, sorry. Probably this is an Octane core issue. Do you know if the same happens if you try to render a scene using the Standalone, not the Layout?
promity
Is somebody have success with OSL node? None of the scripts that I downloaded from the forum are accepted by the OSL node in LW.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
BorisGoreta
When rendering fibers in IPR Layout CPU usage goes to 95% as soon as IPR starts rendering, if I hit pause Layout CPU usage stays at 95% for 15 seconds and then it drops down to usual. MB is off. FiberFX IPR geometry update is off. My guess is that LW is regenerating fibers when it really shouldn't but that is just my guess.
It is correct that network rendering is not working on a second render, activate IPR->close IPR->activate IPR = LW crash, IPR actually continues to render fine.
BorderLine
BorisGoreta wrote:When rendering fibers in IPR Layout CPU usage goes to 95% as soon as IPR starts rendering, if I hit pause Layout CPU usage stays at 95% for 15 seconds and then it drops down to usual. MB is off. FiberFX IPR geometry update is off. My guess is that LW is regenerating fibers when it really shouldn't but that is just my guess.
Yes Boris, same here !
Return to “Lightwave 3D”
