OctaneRender_for_Maya_4.0XB3_-_13.2-Beta[OBSOLETE]
siajans
MAYA Is the most Important Software in the universe you should make everything first for maya
BK
siajans wrote:MAYA Is the most Important Software in the universe you should make everything first for maya
Agree with you siajans!!!
Kind Regards
bk3d
Rikk The Gaijin
siajans wrote:
BK wrote:
deckor wrote:I have updated to the newer build but the script editor is still showing
This is not acceptable ,we are working on a very important project and we need this today ,,,,,,,,
To be fair, it says right at the top in the disclaimer to NOT USE THIS VERSION FOR PRODUCTION.
TDZL
It does not say that access will be cut off without warning though, don't be that guy...
Jolbertoquini
TDZL wrote:It does not say that access will be cut off without warning though, don't be that guy...
Agree with "Rikk The Gaijin"
Seriously, we know for ages we should not use on Production Beta versions and this is writed on the Standalone versions EVERY update of the v4 stop working after update to avoid cracking the soft. same for v3 aswell v2.
I understand your frustration but don't use on production. Let's see if the guys released the 4.0XB4, but my advise is to export on standalone so you can use the 3.08.2 without have this troubles,This is the stable version with all feature only missing the mesh load and denoiser.
I guess the Maya plug for 3.08.2 will be there soon aswell then will be easier.
Just to be clear BETA version is not made to be used with client and on production this is with any render Engine.
This is my point of view here.
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
zurakan
yes and no
octane should post end of the time for beta version
when i test octane i test in real scene for production
it should not cut off activate until new version release
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
siajans
ASAB ====== Give me Time date ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Jolbertoquini
I see, can be frustrating here on our company the same I guess the confusion is because you are new on the forum and Octane Standalone and Plugs. The messages are there but no dates, never mind, we are using for a while now and we know Beta is not to be use on production you can test with new scenes but doesn't mean to use on a real live project.
I also understand the fact for the maya plugs is not so much choice but I think the easy would be to release all at the same time XB4 or keep the license live until every plug has xb4 available.
TDZL
None of what you are saying is helpful, I don't get why it's a debate...
The beta was suddenly deactivated and no replacement has been released. This is bad form but if that's the way it is, that's the way it is.
Backdated to 3.08.1 - 12.46a RC2, scene textures reapplied, Out-of-core memory limit exceeded.
So there is no workaround, everything has to stop until this is sorted...
BK
Hello everyone,
The XB3 release version is back up and running!!! Thanks for your patience.
cheers
Kind Regards
bk3d
