help: CUDA error 700
frankmci
cristiangiro wrote:I always have very dense geometry, since i only render images i guessed having a lot of triangles would not be a problem,
how should i optimise the scene to have a shorter export time and less triangles?
cheers
One tip: If you are using any C4D subdivision surface/hypernurbs objects, instead try using Subdivisions on an Octane Object tag. That can save you gobs of VRAM. It also loads into Octane faster, too. When possible, let Octane and the GPU do the heavy lifting instead of explicitly shuffling all those polys around.
Kalua
cheers
In my case I have zero polygons, shaders,... was fine yesterday. Now I cant do a thing. Im gonna format this OS if I dont find a solution.
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
