OctaneRender_for_Maya_4.0XB3_-_13.0-Beta [ OBSOLETE ]
BK
Jolbertoquini wrote:Hi Bikram,
I have a issue with OSL testure I put the scene here basically, the script crash completely maya if I build with the OSL texture node. But if I use the orbx shader and inside this I do the OSL texture is working perfect, so clear a plug issue there to compile OSL scripts...Please have a look with Jim.
Also try by your self create the OSL texture you will see maya crash! I was using Maya 2018.2 with this plug on Windows 7.
JO
Hi Jo,
Thank you for reporting this.
We have created a ticket on our bug tracking system. Hopefully will get resolved in the next release.
cheers
Kind Regards
bk3d
Maskeline
Hi.
One question ... Anisotropic reflection does not work in the BDRF octane model?
I have a simple scene with a sphere and only the anisotropic reflection works in any model except octane.
There is also a faceting error, which I can not remove
Maya 2018.3
2x 1080Ti
Windows 10
BK
Maskeline wrote:Hi.
Maya 2018.3
2x 1080Ti
Windows 10
Hello Maskeline,
Currently, Octane Anisotropy is working on geometry normal interpolated. We would be adding geometry tangent interpolation feature in our future release.
In the meantime, please use it in smoothed mesh or use OpenSubdiv.
cheers
Kind Regards
bk3d
zurakan
HELLO Mr.BK
Can You make option Add or Screen Mode for OctaneMixMaterial ( or Osl texture ).
thank so much
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
Rikk The Gaijin
I just installed this version and tried it on a scene I'm working on saved with 3.06.
After 10 seconds or so of rendering, the PC freezes completely, needing an hard reset... :roll:
No problems at all with 3.06.
BK
zurakan wrote:HELLO Mr.BK
thank so much
Thank you Zurakan for this. We are having a look if we can make something like this using OSL.
cheers
Kind Regards
bk3d
BK
Rikk The Gaijin wrote:I just installed this version and tried it on a scene I'm working on saved with 3.06.
Thank you for reporting this Rikk. Will do another release soon.
Cheers
Kind Regards
bk3d
BK
thank so much
Hi Zurakan,
We found an OSL from 3ds max 2019 and sort of make it compatible with Octane for Maya, still to do more improvement. It works better when we use the ORBX material and Maya nodes using Hypershade to plug the two nodes.
Hope you will find this helpful.
BlendModes.7z
(1.47 KiB) Downloaded 239 times
Kind Regards
bk3d
