OctaneRender® for Maya® 3.08.1 - 12.46-RC2 [ OBSOLETE ]
BK
gah5118 wrote:installed; tried to export alembic; crashed; uninstalled and reinstalled 3.06t4 - 10.12 ; back to work.
Thanks again for this!! The crashed is caused by the engine and has been fixed in 3.08.2 sdk.
Kind Regards
bk3d
Jolbertoquini
BK wrote: The crashed is caused by the engine and has been fixed in 3.08.2 sdk.
Do you know when is going to be released the 3.08.2? if will be released.
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
BK
JO
Hi Jo,
I am sorry !! no idea yet when it is going to be released but the crash issue seems to be resolved.
cheers
Kind Regards
bk3d
Larrie_Fran
BK wrote:
Rikk The Gaijin wrote:Bug. When using Octane viewport, if the Resolution Gate is active, the image get stretched to fit the viewport size, rather than keeping the correct aspect ratio.
Hello Rikk,
Thank you for reporting this issue. We are looking into this. Would you please try going full-screen mode ( Ctrl + SpaceBar ) and the same shortcut to come back to normal view, just to see if the stretch still happens?
cheers
Hi BK, I tried for him. The stretch remains in all views :)
Cheers, hope to see this plugin version in a stable state really soon, it would be really helpful
BK
Larrie_Fran wrote:
Hello Rikk,
cheers
Hi Larrie,
Thank you so much for your help :)
We have done few fixes related to image stretch in the viewport render but would you mind upload or PM me a screenshot just to compare.
Yep, if you find any suspicious bug, please feel free to report while we wait!!
Cheers
Kind Regards
bk3d
Larrie_Fran
Hi @BK,
I rebooted the PC and now the problem seems to be disappeared.
BK
Larrie_Fran wrote:Hi @BK,
Hi Larrie,
Awesome !! thank you for letting us know. Hope we can resolve this in the next release.
Kind Regards
bk3d
TDZL
Think I have found a thing.
When batch rendering Bifrost fluid meshes, some frames it renders the mesh, some frames it does not and it's not always the same frames.
- Simulation cached
If i move the slider on the timeline after the cached data and batch render the scene, the mesh shows in all frames, although none of the frames show the material (Octane Spec), instead just being white.
If the time slider is withing the cached data on the timeline. the mesh is visible in random frames but when it is the material is applied.
Everything is completely fine when frames are rendered individually (not batch).
- Animator Data set to "forced load"
- Bifrost meshing on
Tried:
- Exporting as Alembic.
When loaded into a new scene mesh is randomly in certain frames and not in others.
- Direct Light / Path trace - No difference.
BK
TDZL wrote:Think I have found a thing.
- Simulation cached
Tried:
Hello TDZL,
Thank you for reporting this.
We are currently investigating it now. Hope to solve in the next release.
cheers :)
Kind Regards
bk3d
itsallgoode9
Any idea of how close we are to a stable build? The last stable build is nearly a year old at this point :shock:
