Octane Render for SketchUp 3.08.1.0 Stable Release
manos
Hello....i use the plugin as an exporter to the standalone ....but the material picker is not working ....any way to fix this ?
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
azen
manos wrote:Hello....i use the plugin as an exporter to the standalone ....but the material picker is not working ....any way to fix this ?
Hi Manos,
Just to clarify - are the Materials in the Sketchup Material Picker not applying to your geometry? Are the materials applied from the Sketchup Material Picker not showing up correctly inside the Octane Viewport? Any specific details about how the Material Picker is not functioning correctly would be greatly appreciated, as this will allow us to replicate the issue on our end.
Also, please confirm the SU version, OS, and CUDA Driver version numbers on your machine.
Azen
manos
The su I use is 2017 but I think I had the same problem with 2018 also....It seems that when exporting from su the picker doesn’t respond like nothing is picked....but when exporting a obj or from 3d max it works fine...It has to do something with the file that the plugin produces ....
Return to “SketchUp”
