OctaneRender® for 3ds max® v3.08.1 - 5.09 [OBSOLETE]
Norman_Stansfield
rogerteddy wrote:Octane Object Properties are messed up here.
best
r
I confirm here too. Using max with windows 10 and 3840x2160 resolution (system scaling 175%). Properities window is now useless - glitches and options stuck on each other. Too bad, I wanted to play with subdivision options. Seems a premature build relase. Please fix scaling asap or just undo it because subdivision is more important than Properities scaling.
Best
nl
paride4331
best
r
Best
nl
Hi guys,
are you talking about UI?
3dsMax version?
Windows 7 and 3840x2160 everything works well.
Could you kindly share a screenshot about your issue?
Regards
Paride
neonZorglub
best
r
Best
nl
Hi guys,
3dsMax version?
Regards
Paride
Thanks for letting us know. This happens indeed when setting the "Change the size of text, apps, ..' in Scale and layout of windows Display settings (Windows 10) , and log out / re log in to Windows, so that 3dsmax take the change into account.
Several other Octane UI are incorrectly displayed (osl shader, user settings)
I will release a fix shortly, hopefully today.
As for the V4, it's almost ready. We will try to release it next week. Note that it's based on the Experimental Octane SDK 4.0 XB2, so not advised for production work..
Regards,
NeonZorglub
coilbook
converting vray mat and saving crashes max
can you open and resave the scene it crashes max thanks
corals.zip
(1.09 MiB) Downloaded 243 times
neonZorglub
coilbook wrote:converting vray mat and saving crashes max
Hi Coilbook,
I didn't get any crash resaving your file (max 2018)
Your scene has only a standard material, but I tried some vray scene, no problem either .. with or without material conversion ..
Your problem doesn't seems related to material ..
I did load and resave with max2019 too..
It might be caused by a conflict with another plugin ..
Could you Enable Extra log in 'trouble shooting', and check / post the log file (Octane3dsMaxLog.log, that can be found by 'Explore Octane Log Folder' button) ?
