OctaneRender® for 3ds max® v3.08 - 5.06 [OBSOLETE]
neonZorglub
coilbook wrote:Hi PHoenix 3.10.01 liquid particles like splash and foam still dont work with octane 3.08 . Scene attached
please fix it is getting annoying switching back and forth from 3.07 to 3.08 and switching phoenix all the time.
Hi Coilbook,
Thanks for your scene. I think I found the issue with the particles not being rendered :
When 3dsmax starts, it seems to not always call Octane when all plugins are loaded, so it could miss the detection of Phoenix FD.. I got different behavior with Phoenix for VRay and Phoenix for scanline ..
This should be fixed in the new release, 3.08 - 5.07..
Note that I also added some check / information for Phoenix volume channels, that can be useful to better understand issues with volume settings..
I'll have a look at the performance issues..
neonZorglub
wrapthereal66 wrote:in fact the error come from octane putting a " : " in the name of the render passes ! this cause the error ! so need to fix by myself ! :/
Hi wrapthereal66,
Sorry about that ! This should be fixed in the new 3.08 - 5.07
coilbook
Hi Coilbook,
Thank you! I'll be testing it today
paride4331
Hi Coilbook,
Seems to works fine.
coilbook
Hi Coilbook,
Hi neonZorglub
if you need the scene for the performance issue (scene evaluation) please let me know. It is literally 1 min 20 seconds to process Phoenix ocean and a couple of objects before rendering begins. And I have i9-7900x Thanks
nick73
I am using 3ds max 2016 plugin, 3.08 5.06 subscription and it seems that I cant change response, gamma etc on camera imager settings. On standalone everything works fine.
