Sooooo, Octane 4 MODO plugin?
Now that a new API is mentioned...
Where is this mentioned pls?
Hesekiel2517
https://youtu.be/ObDlrFwveoU?t=51m59s
Here you are :)
Its about ProRender. Shane says they are not only developing a Plugin but an API which can also be used by other Renderers
Great link - thanks for sharing. It sounds like this might be some time off, but still could benefit the plugin substantially.
portnicki
Hey Paul,
any advances on Octane 4 modo plugin?
cheers,
Wojciech
i7 2600k + nVidia TITAN black
https://www.behance.net/Auror
Greg
Looking forward to seeing if Octane will load/prep geometry faster. Sometimes it takes longer to load the geometry than render the scene (for doing things like opacity passes).
Paul - are you going to Siggraph?
-G
CEO Sabertooth Productions
Co-Founder Pixel Fondue
I am still not certain XB4 is working correctly with the Modo plugin, and it might need XB5. I will know more in the coming days.
No Greg, not going to Siggraph.
Tharso
Greg wrote:Looking forward to seeing if Octane will load/prep geometry faster. Sometimes it takes longer to load the geometry than render the scene (for doing things like opacity passes).
-G
Thats my main problem !!! =/
Octane for maya is much faster.
Greggers
Any news on the modo plugin update for version 4 dudes?
If there are no showstoppers found with the RC1 build of the plugin, it should be available in the next day or two.
Hesekiel2517
Good News! Can't wait to test it :)
Btw did you see the new PublicBeta of ProRender for Modo? Seems like the new Api will be available in the near future..
Return to “Foundry Modo”
