No Problem, thanks so much for looking into this...
one simple test you can also do is make a sphere,
send to layout,
add fiber fx,
right click on layer and select polygonize guides,
save the object, and then make the quads subpatched.
This should crash octane when attempting to render.
Note. it will not crash if object subdivision level is set to zero.
Fiber guides and Texture UV's
Sorry, I can't reproduce the problem following these steps. Can you attach the scene?mstewart152 wrote:No Problem, thanks so much for looking into this...
send to layout,
add fiber fx,
- mstewart152
Thanks Juanjgon.
I figured it was a Lightwave bug, usually is lol.
I still get a crash with display level at 0 and F9 at 3. But ill try some more.
- mstewart152
Using Octane Object properties subdivision might be a work around here
I've fixed the crashes, but I'm afraid that due to the problem on the LW side, the fibers UV texture coordinates are broken if the base object is subpatched. And this happens with the IPR and with the final rendering. Only objects without subpatchs are supported currently as UV source for the guides. I'll report this issue to the LW team, to see if it can be fixed.
Yes, sure. If you use the Octane native OpenSUBD feature to subdivide the base object, the fibers are going to be rendered with the right UV coordinates. Remember to set to 0 both the display and render subdivision level in the LW object options.mstewart152 wrote:Using Octane Object properties subdivision might be a work around here
