OctaneRender® for 3ds max® v3.08 RC1 - 5.01/5.02 [OBSOLETE]
Thank you very much mbetke ! Works fine !
- wisemanxxx
When I click UV transform slot (2d transformation) in RGB texture for changing uv positions it shows Material/Map browser and projection maps (box,spherical,osl projection etc.). If I choose any then puts in projection slot. Never enter UV transform.It happens in an old project saved with 3.06 - max 2018.. Scene has some fbx links and AXYZ Anima models.Nothing more.
- kcpr-raffaEl
- Contact:
This version desn't see my GPUs (1080Ti + 2x1070).
Shall I install newest drivers?
I use 382.53 since they seems to be most stable.
- paride4331
Hi wisemanxxxwisemanxxx wrote:When I click UV transform slot (2d transformation) in RGB texture for changing uv positions it shows Material/Map browser and projection maps (box,spherical,osl projection etc.). If I choose any then puts in projection slot. Never enter UV transform.It happens in an old project saved with 3.06 - max 2018.. Scene has some fbx links and AXYZ Anima models.Nothing more.
Yes I alredy reported yesterday this issue to developer.
Regards
Paride
- paride4331
Hi kcpr-raffaEl,kcpr-raffaEl wrote:This version desn't see my GPUs (1080Ti + 2x1070).
from 388.13 from here on out.
Regards
Paride
- kcpr-raffaEl
- Contact:
Thank you!!paride4331 wrote:Hi kcpr-raffaEl,kcpr-raffaEl wrote:This version desn't see my GPUs (1080Ti + 2x1070).
Regards
Paride
Is 388.13 most stable or rather go for newest 391.01?
- paride4331
Hi kcpr-raffaEl,kcpr-raffaEl wrote:Thank you!!paride4331 wrote:Hi kcpr-raffaEl,kcpr-raffaEl wrote:This version desn't see my GPUs (1080Ti + 2x1070).
Regards
Paride
some users have 391.01 issue with , I'm using 388.13 and all works fine.
Regards
Paride
- paride4331
Hi thekwen,thekwen wrote:Otoy team ? Someone ? This is not the first time i ask without answer ... So what is this a taboo subject ?thekwen wrote:Motion blur with liquids/abc files ???
Hey houston plz respond !!!
sorry for delay to reply, I'm testing new version looking for issue. Don't worry, nobody forgot your issue.
could you take a look here?
viewtopic.php?f=33&t=65518
Could you share again your .abc test you sent please? I sent it to developers and deleted it, but I would like to make another test.
Regards
Paride
- neonZorglub
Hi HHbomb,HHbomb wrote:PS : in "osl_projection.max" file, I cannot edit osl script via max UI, but I can edit and modify it via octane node viewer in max.
I could see this problem; I should post an updated test version soon with this fixed, and other issues found. Thanks !
