OctaneRender™ Standalone 3.07 TEST 3
enricocerica
abstrax wrote:
enricocerica wrote:Great, thanks for this rebound.
Any news about the denoiser ?
We are working on it and the first results look promising.
Great new !
http://www.myline.be
mac3d
Fantastic job..
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
Dmi3ryd
Thank you very much for new release! Great job! 8-)
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
lukas8410
I may be wrong, but I think that I saw some PBR materials support in Octane roadmap,
does this means that working in substance painter > Octane workflow will be simplified?
Luke
// Behance: https://www.behance.net/LukaszKondek //
- Octane v3
- 1x Geforce 980 Ti , and 1x 570 GTX
ramone163
Any news about Octane Imager?
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
coilbook
uncia wrote:Dear Otoy team can you please look at this old problem when you have some time
viewtopic.php?f=23&t=52965&hilit=uncia
And can you speed up voxelization process ? It's a real pain in one of my body parts :)
And thank you for your hard work.
same here/ we have not heard you discussing this like it is not an issue
enricocerica
I probably missed something but I cannot use the gizmo to move/rotate/scale an object.
I add a placement node for a mesh, select it and activate any of the transform icons but don't get any transform icon whatever is the gizmo mode (local or world).
Any tips ?
abstrax
enricocerica wrote:I probably missed something but I cannot use the gizmo to move/rotate/scale an object.
Any tips ?
Is the mesh being rendered, i.e. connected with the render target node you are currently rendering? If yes, then that sounds like a bug in which case it would be great if you could remove all other geometry and send the scene to us? Thank you.
abstrax
We are working on the geometry compilation speed. Mostly for version 4, but some changes may also trickle down to version 3, but that's not clear yet. We will let you know in the coming weeks.
Unfortunately we can't solve all problems all at once ;)
abstrax
Any tips ?
Ok, it seems you have to enable the object picker tool (see viewtopic.php?p=320255#p320255). We will fix the bug in the next release. Sorry about that.
