I was hoping you guys used the output of the standard shader code, but you seem to just grab the _MainTex. I was in the middle of writing a splatmap shader hoping it would be that simple ... at this point, clearly I just have to wait. Really though, without a good way to handle terrain we just can't use this yet ... so I'm eagerly waiting
Unity terrain
Moderator: ChrisHekman
Any eta on OSL or the terrain stuff in specific? Obviously a native solution would be great since we already have the tooling for terrain, which would make the workflow very nice.
We'll have more details on OSL once 3.07 is out, as 3.10 will just be a few updates away.
- walkerxian
Hi,@Goldorak.
I recently used Octane Rendering Unity terrain, and we can not render. I would like to consult now if have other third party solutions? There is also a question, probably when the octane can support the unity terrain rendering
Thank you very much,thank you for your contribution to Octane.
- ChrisHekman
Terrain is currently in development. It should be part of the upcomming build, or the build after the upcomming one.
After the terrain is doen, we will look at terrain trees and grass.
- adamgoodrich
Awesome - looking forward to this - and re-iterating previous comment - am happy to adapt my toolset to support this.
Will it use the standard terrain tools? A subset, or all? How will this work when blending two different textures? Will it use height blending? Basically, what should we be expecting? Very excitedChrisHekman wrote:Terrain is currently in development. It should be part of the upcomming build, or the build after the upcomming one.
- ChrisHekman
It uses the standard unity terrain and when it is finished it should work "out of the box". Texture tiling and blending works the same as unity.EFS wrote:Will it use the standard terrain tools? A subset, or all? How will this work when blending two different textures? Will it use height blending? Basically, what should we be expecting? Very excitedChrisHekman wrote:Terrain is currently in development. It should be part of the upcomming build, or the build after the upcomming one.
After the terrain is doen, we will look at terrain trees and grass..
As for height blending, this should already be possible in unity itself. You just need to create your own blendmaps via code. This will then show up in octane.
I noticed that the Terrain now shows up in Octane. However, is there any way to have add additional textures, such as heightmaps? Right now the difference in quality between what the terrain gives vs. what a mesh with full texture maps available (especially displacement) is tremendous. Unless, of course, I just don't know somethingChrisHekman wrote:It uses the standard unity terrain and when it is finished it should work "out of the box". Texture tiling and blending works the same as unity.EFS wrote:Will it use the standard terrain tools? A subset, or all? How will this work when blending two different textures? Will it use height blending? Basically, what should we be expecting? Very excitedChrisHekman wrote:Terrain is currently in development. It should be part of the upcomming build, or the build after the upcomming one.
