Problem Rendering Sequence
neonZorglub
Hi unpolbo,
This warning should not affect the final rendering, it happens sometimes, and only when reading the rendered image the first time.
To avoid this message, you can uncheck the 'Enable Extra Warnings' in Octane global preferences, tab 'Trouble Shooting'.
Alternatively, you could try to set the Render width and height in Kernel settings same as the Output size in Common tab, and uncheck the 'Use production resolution'.
I hope this will fix your problem.
A better fix will be added in the next release, 4.40
kcpr-raffaEl
OK,
I've made more test and here are my results:
- This problem seems not to be related with "Assertion type WARNING: condition "0" failed..." - because this warning appears always, during rendering.
- BUT OCTANE stucks on saving result image and cannot proceed to render next frame - this seems to be the real problem;
- With Max 2016 version 4.39 crashes 3ds Max often;
- 4.39 has more issues than this one only - for example hanging during processing some objects - which has no place until 4.38 version.
- I reverted to 4.33, since for now this is only one version where I can do any production.
Return to “Autodesk 3Ds Max”
