Scene Evaluation takes forever
coilbook
paride4331 wrote:Hi laihinchun,
mark0spasic is right, your issue probably depends on RAM, Octane Render eats a lot of RAM in the voxeling phase.
3dsMax eats a lot of RAM too, probably your OS works in paging and stacks and slacks.
Paride
i think OCtane 2 viewport was much faster.
matthewcastiglia
I am having this issue too. It takes 10 minutes to finish the scene evaluation.
Win 10 64 | Geforce GTX 970 SLI | i7-5930K | 32GB
http://matthewcastiglia.com
coilbook
matthewcastiglia wrote:I am having this issue too. It takes 10 minutes to finish the scene evaluation.
do you have any pflow in your scene?
justix
I have the same issue were a generic scene that I'm testing takes 45 Seconds to load and start VS 10 Seconds of the XB3 Standalone ( 45 tx and 4740973 triang and 2mb Memory used ) is a huge gap :?
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
paride4331
justix wrote:I have the same issue were a generic scene that I'm testing takes 45 Seconds to load and start VS 10 Seconds of the XB3 Standalone ( 45 tx and 4740973 triang and 2mb Memory used ) is a huge gap :?
Hi Justix,
try to use new v3.08.2 - 5.12 or v4.00-XB3 - 6.02 [TEST] releases: Improved Material editor performance: added cache and down-scaling of Material preview images : see new tab 'Material' in user settings.
please use minimal refresh time in viewport settings to 0 ms. Added option to set this refresh time to 0 automatically when loading previous scenes (enabled by default, see option 'Optimize Refresh time for old scenes' of 'Viewport' tab in user settings).
Regards
Paride
justix
Hi Justix,
Regards
Paride
hmm thanks it seems to lower to 18 sec now..still crashes on out of 2 on opening projects..investigating
matthewcastiglia
I do not
coilbook
paride4331 wrote: Mon Jul 31, 2017 10:10 am Hi laihinchun,
Paride
Hi Paride,
I am actually not even using half of the vram. It's only 47,000 tyflow chunks. Eval times are 5 min per frame! I'll try to send the scene.
paride4331
Hi coilbook,
That would be helpful.
Regards
Paride
HHbomb
Shouldn't evaluation be on gpu soon ? It was anounced... ( like Brigade )
Return to “Autodesk 3Ds Max”
