OctaneRender® for Maya® 3.06 - 10.21 [OBSOLETE]
BK
renmaxhb wrote:another bug,poly will lost matrerial when copy abc poly at instance
Hi renmaxhb :)
Sorry for the late response. Can you please confirm if it still does when you refresh IPR also what happens when you hit render?
Kind Regards
bk3d
BK
Hi Jo :)
Thanks for reporting this. We are looking into this now, hopefully will get it fixed as soon as possible for you.
Kind Regards
bk3d
renmaxhb
Hi renmaxhb :)
I sure ,I render one maya file of my project with 6 renderfarm, the first frame lost material in every deadline task.
This will be same in mayabachrender .
renmaxhb
hi,BK,
where is the fix vision,
Let it go? :roll:
calus
The separate "Layer Reflections" pass name is wrong, it should not use the _refl suffix, which is already used for the "Reflection" pass.
BUG : Layer Reflection pass overrides the Reflection pass at render time.
Separate passes should just use the user-defined Exr Channel names so these mistakes with the hard-coded names could not happen.
Pascal ANDRE
