Backburner and network rendering
Morevision
Hi Paride,
Thanks for reply!
As request it would be really great to have solution from Otoy for Backburner use. The way it works in Cinema 4D - Octane plugin uses native instrument for render queue with support of Network rendering.
Batch render is ok for stills but it's a pain for sequences and large amount of different scenes to be rendered. Of cause, everything could be solved by installing additional graphic cards. But currently it's not affordable solution.
regards,
Andrew
paride4331
Hi Morevision,
you should be able to use your computer with backburner as master/slave simultaneously and Octane render network to connect other GPU's.
Paride
Morevision
Hi Paride,
Thanks for explanation and help!
Still looking forward for backburner solution with use of network graphics cards. Or anything else working that way.
regards,
Andrew
Return to “Autodesk 3Ds Max”
