It crashed again with the resolution of 875 x 575px.
I hardly can believe that I'm the only one Win XP user, there must be alot of other XP-users having that "timeout-problem", don't you think so ?
Is there nothing I can do against it ?
Kind regards
Alain
Crash after a few minutes of rendering
Hi,Alain wrote:It crashed again with the resolution of 875 x 575px.
Kind regards
Alain
unfortunately not, XP does not allow to change this behaviour,
i would recommend upgrading with win7 to fix this...
XP is now nearly 11 years old...
Radiance
...but XP does it's job very good.
I guess Win 7 uses more (unecessary) hardwareresources, I have not seen any useful advandages in Win 7 (Examples: The new File explorer is very confusing compared to XP (at work I've aready installed "free commander" because it does what it has to do
), the new mac-like "super searchfunction" does not find files that should be found,...). OK you can say I'm just to stupid to know how to use Win 7
...maybe I should install linux ?
Kind regards
Alain
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
Well, the driver model has changed a lot between Windows XP and Windows Vista/Windows 7. So expect more and more problem in the future with Windows XP. That's just the way it is.Alain wrote:...but XP does it's job very good.
I guess Win 7 uses more (unecessary) hardwareresources, I have not seen any useful advandages in Win 7 (Examples: The new File explorer is very confusing compared to XP (at work I've aready installed "free commander" because it does what it has to do), the new mac-like "super searchfunction" does not find files that should be found,...). OK you can say I'm just to stupid to know how to use Win 7
Kind regards
Alain
Marcus
It works fine if you have a 2nd GPU for octane, which does not have a display attached to it, so XP is useable.
As there is no display watchdog timeout registry key, you cannot prevent it from closing octane if it uses your GPU with a display attached to it for more than a few seconds...
If you want to continue using XP, you could get a cheap nvidia display GPU, use it as your primary adapter with your monitor(s) connected to it,
and leave your grunty GPU headless for rendering with octane, this will also give you a smooth/useable desktop while rendering.
Radiance
Radiance
YES, just do it!Alain wrote:...
Kind regards
Alain
use linux! linux is slim and fast.
i love it since the first day i installed it.
win7 and its new "fancy" features like the browser is a pain imo. -very macadized:(
i made a dualboot system win7/ubuntu. most times ubuntu is up:) win just for a few programms which are only available for win..
btw i used xp32/octane for a while and never experienced any time outs using one gtx470..
cheers dave
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
@dave
I'm just trying to install Ubuntu on a dual boot.
Having some problems to install a root filesystem partition for Ubuntu (I used the Windows Installer) but I'm sure I'll solve the problems and I hope it's worth the work
Kind regards
Alain
Kind regards
Alain
Ok, I gave up to install Ubuntu. Had problems to install the Masterbootsector. It's because I have an old IDE Harddrive connected to a SATA (by an adapter). And the Ubuntu installwizard does not recognise my OS and Harddrive correct. Wasted to mutch time -> ordered Win7 and hope it helps
BUT, I discovered, that when I turn off the Windowx XP Screensaver Octane doesn't crash anymore.
Kind regards
Alain
Kind regards
Alain
It's always best to disable screensavers with octane, as they usually use 3D graphics, which can tax the GPU and cause stability problems with drivers...Alain wrote:Ok, I gave up to install Ubuntu. Had problems to install the Masterbootsector. It's because I have an old IDE Harddrive connected to a SATA (by an adapter). And the Ubuntu installwizard does not recognise my OS and Harddrive correct. Wasted to mutch time -> ordered Win7 and hope it helps
Kind regards
Alain
Radiance
