Version 3.04.5-R2 (05.12.2016)-Previous stable
atome451 wrote:For your information, there is no node anywhere for the "W Coor" in the Node Editor interface.
By the way, it works fine if you add the "W Coor" node from the standard C4D material editor. Not a big problem then... :roll:
Thanks! I could just did such until now. I didn't wanted to hold a release which is important for someone.
carterner
the light pass is different with old version
abstrax
carterner wrote:the light pass is different with old version
That's a bug I introduced in 3.04, which will be fixed in 3.04.1 which we are building right now.
carterner
thank you
Version 3.04.1 is up now. Enjoy it!
KonstantinosD
Something is wrong in this version, this is the same render after 1min 6 sec on my system on both renders. You can see the first one is clear and light is nice 3.04, but in the second one 3.04.1, the light is all messed up and very noisy on the same time/samples.
I also provide the scene but without the floor texture.
first,
second,
scene,
https://dl.dropboxusercontent.com/u/348 ... 20test.rar
Thanx,
2X Win10 PRO, Asus ROG Zenith Extreme Alpha, AMD 2990WX , 64GB ram, 2X 2080ti, all watercooled, custom loop.
artdude12
I tried both versions as well and am getting the same results.
C4D R18
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
artdude12 wrote:I tried both versions as well and am getting the same results.
C4D R18
Do you mean same wrong results or same on both versions 3.04 and 3.04.1?
artdude12
3.04 is rendering the file like the first image that KonstantinosD posted.
3.04.1 is rendering the file like the second (darker) version.
Both with R18
KonstantinosD
Also, when i test the scene on the latest standalone it renders fine, in C4D it is much much darker for some reason and as you can see noisy and wrong. It seems like the exposure is messed up.
