CUDA Error 700...
jang2235
juanjgon wrote:
Lewis wrote:Juan do you have Pascal GPU(s)now ?
Not yet, I am waiting for a new Pascal laptop ;) ... anyway I can add one to my Windows workstation to make some tests if nobody else can reproduce this problems from Standalone. Do you know if only one Pascal GPU is enough to reproduce it?
I tried to find the cause of the problem by investing my time yesterday.
The Maxwell TitanX and Pascal TitanX find that the error was caused by what the same conditions.
I while disabling Instance found that the error does not occur.
Instance disable all of the trees in the same Scene overnight and there was no error was made rendering.
I do not know what the problem on the part Pascal TitanX was a problem in the Instance part.
Lewis
jang 2235 - can you send that LW scene to Juan ? The one which was crashing.
I can test same on my machine to see.
As soon as i get some time between project i'll try to investigate on my side also.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
jang2235
Lewis wrote:jang 2235 - can you send that LW scene to Juan ? The one which was crashing.
Now I'm being tested.
This is to ensure that the issue of the problem is that Pascal's on my network settings or something else .... Thought is the day about those tests.
So far, this problem does not appear lucky.
jang2235
I tried to find the cause was a failure.
And even when rendered properly. It also occurs Cuda 700 Error.
Network problems are ahningeot.
This can not determine whether the failure to render certain conditions.
It is certain that the Mexwell TitanX normally takes.
jang2235
Nvidia Driver 372.70 Good
Nvidia Driver 373.06 or 375.63 Bad Cuda Error
Not a good thing that the latest.
But Titan X Pascal Error is the same.
amathews9518
what gforce driver should I be using
W764 2xE5 2650 3-780(3GB) + 780TI(3GB) Asrack EP2C602 40gb Lightwave & Chief Architect
jang2235
amathews9518 wrote:what gforce driver should I be using
I was a hasty decision.
It seems the problem rather than the problem of drivers of LW2015.
Still under test in a variety of ways.
Return to “Lightwave 3D”
