Animating focal depth
jtmsf
I'm using Octane 4, and I'm having the same problem.
Camera focal length animation isn't exporting correctly to .OCS with "octane.saveAnimation"
I'm attaching the Modo scene and the OCS export.
Thanks in advance.
Intel Xeon E5-2680 v3
32GB RAM
GPUs 2x GTX1800TI
Windows 10 64bit
OctaneRender 4.00 (4000021) (installed with "OctaneRender for Modo 4.00.0.137" link)
Nvidia driver 417.35
Modo 12.2v1
OctaneModo_FocalDepthAnimation.zip
Modo Scene and OCS Animation export
(188.24 KiB) Downloaded 229 times
jtmsf wrote:I'm using Octane 4, and I'm having the same problem.
Thanks in advance.
32GB RAM
GPUs 2x GTX1800TI
Windows 10 64bit
Modo 12.2v1
Hi. I loaded your scene and then octane.saveAnimation, and the loaded the resulting file into Octane Standalone, and the Camera->Focal Depth was animated correctly as per the scene in Modo. Modo 12.2v1. So I was unable to reproduce your problem.
jtmsf
For me the problem existed: In modo the animation was fine, but after exporting and opening in standalone the focal depth stopped updating the animated values after some frames.
I eventually managed to solve this issue:
1) I added one keyframe before, and one a keyframe after the existing octane focal depth keyframes in modo.
2)I reexported using the "octane.saveAnimation" command and now in standalone the animation was correct.
Hope this fix will help other users.
Return to “Foundry Modo”
