New nodes feature discussion towards v1.0 final
radiance
Ice_Juice wrote:And what about the promise of a new engine?
It is expected in version 2?
If you are talking about the new render kernel it's in development and is not the topic of this thread, this thread is to discuss the addition of nodes for building more complex macros...
I will wait a bit to get some more replies / feedback before I respond to the other people's suggestions.
Radiance
Scog
I would like to see a fresnel node, or nodes necessary for creating one (such as an incidence node). This is needed to create accurate metalic (Conductor) materials, as currently only Specular (Dielectric) accepts an IOR.
I'd also like to request more descriptive labelling throughout the package. something like 'Refractive index' or "IOR" rather than just "Index".
The Idea is that if someone wants to know what a slider represents, googling the label will give relevant results.
I imagine if you were to add an "Index" slider to the glossy material, a significant number of people would have no idea what it was for.
Another solution would be to add tooltips Describing the role of the node in question. It would also be nice if these were customisable for making macros, and could be used like code comments to help users understand how they work.
| Desktop: GTX480 + 8800GTS 320MB, q9550, 4GB RAM | Laptop: Quadro FX 880M 1GB, i7 820m, 4GB RAM |
Elvissuperstar007
Оо!!! it will be awful
Elvissuperstar007
falloff shader needed
PeterCGS
Please keep this topic clear.
*I would like to see the addition of integer values in the image nodes, that controls input sequence for images (So you can control which image Octane loads from a framestack through plug-ins (image sequences)).
*Also distance from camera nodes. That would be excellent as a mixer node for example, so you can mix a "far off" material with a close-up material.
*AO node that isnt tied to the direct light AO input value, with procedural alpha overlay. Also for mixing materials (create dirt etc).
*Shadow Receive on/off node.
*Shadow cast on/off node.
*Stack nodes with different bledning modes like add/screen/multiply/subtract etc. (Stack materials upon eachother vs material mixing node)
*Gradient node with spline/linear smoothing that accepts camera incidence/black body emission incidence/Distance to camera/distance to mesh/surface thickness
*Matte node. Alpha black/white (custom alpha creation based on materials, instead of only atmosphere)
*Double sided/single sided normals node
Thank you! :)
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
Magog
Yep! Fantastic!
* anisiotropic node.
* node environment (to use textures for reflection in daylight system. Very useful for outdoor scenes!)
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
suhail_spa
procedural textures:
- ramp
- normal ramp
- fresnel ramp
- fresnel conductor
it will be great with these.. :shock:
and:
- wireframe procedural texture
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
face
PeterCGS wrote:Please keep this topic clear.
Thank you! :)
I know that you use Softimage ;)
You can do all the texture stuff inside Softimage and render it out as a rendermap.
The exporter looking at it and generate each frame a new image...
face
http://vimeo.com/user2509578
PeterCGS
haha.. Ok, thats how long it worked trying to stay on topic (sorry Radiance) :)
I use Lightwave aswell... Stuff aren't working as good there :P
I didn't know you already could use animated textures with rendermaps? Must have missed it. Do you have any post how to set it up Face? You post too much goodies, so its hard to know whats being working on, whats already in there, and most importantly, how to use it :) (I never ever have rendered anything in MR (n00b), except depth/alpha mattes.. thats about it)..
grimm
PeterCGS wrote: *Shadow Receive on/off node.
I don't know if I would want these options. They are biased which doesn't fit very well with Octane's unbiased nature. :) I guess it's a matter of opinion, but I want the shadows to fall as they would in the real world.
Grimm
