Maybe this will help identify where the issue is:
If you connect a node upstream to an Octane Material (Standard or Mix), then disconnect it you can then make downstream connections and they'll be displayed correctly in the NE. This also works for any child nodes you connect to that node.
If you don't connect to an Octane material first then none of the connections will be displayed correctly (though internally they are being made). It seem like connecting to a Material switches on the display of connections, though I'm sure it's more complicated.
Crash connecting material nodes (scene attached)
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
