OCTANE Viewport does not work with BODY OBJECTS
Thank you!
I'll look into it...
oguzbir
I'll try and answer it.
To see the high resolution version in the octane viewport do the following.
1- set the viewport display setting as you did Fine and Both This is setting only for the max viewports
2- This is where you loose it. Go to the Render approx. settings tab. (in the body object )
And set use viewport setting as renderer. Cant remember the exact phrase. but it's similar to that..
Close and restart your octane viewport.
Voila
My Portfolio
azen
Apologies for the issues you faced trying to post your original message. It seems that certain words and phrases triggered our anti-virus security. I am currently looking into whether this is a flaw that needs patching, or a very rare anomaly.
Thankfully, your requests and attachments ultimately came through, and your issue is being addressed for a future release. Apologies again for the inconvenience.
Azen
richardyarlett
THANKS !!!
That works pretty damn well. I really appreciate that. I guess that is an old trick with a new solution. I never thought to check in there.
Return to “Autodesk 3Ds Max”
