Could not find any available licenses
supermassive
bepeg4d wrote:mmm, weird, here is how it should work:
v3.00TerminalSignOut.mp4
I would try to deactivate v3.00 and then try with v3.01:
viewtopic.php?f=24&t=54632
I appreciate you helping me out man. I redid the terminal thing (using select all to make sure I had exactly the right code), but it still showed me the same error message. I then clicked 'sign in as another user', it then showed me the login screen. After that I quited Octanerender redid the terminal command and it went straight to the login screen, the same as in your video.
Then I downloaded Octane v3.01 using the link you provided. Opened that up, logged in using my credentials and got the error message 'Could not find the required license - Unable to find the required license'.
The Octane Licenses screen remains unchanged.
Sorry, I guess that there is not much more I can do :/
I'm going to report your situation to NZ, hopefully your issue will be sorted asap.
supermassive
bepeg4d wrote:Sorry, I guess that there is not much more I can do :/
Thanks man appreciate it! I've also contacted support, I really NEED this resolved by friday because we'll be showing renders to our client by then.
mz
I have exactly the same issue. My Standalone is working and has access to the license. When i open C4D he tells me i have no License left.
Also your example works for me, i can log out with terminal. When i open Cinema then i get the message "Could not find available licenses".
Thanks for your kind help!
mz
I think i found the solution for my case. I just have ordered the Standalone License which is not working for Cinema4D.
I try to exchange it now and hope it works.
rhirtz
I'm having the same issue. I upgraded to v3 the other day, and everything was working fine, until today. After restarting my machine, and opening up C4D, I'm getting the "could not find any available licenses" error.
Anyone else running into this error? Or finding solutions???
I too have renders needing to go out to client, and am at a standstill now. Maybe I just need to scrap v3 and go back to v2.
mojave
rhirtz wrote:I'm having the same issue. I upgraded to v3 the other day, and everything was working fine, until today. After restarting my machine, and opening up C4D, I'm getting the "could not find any available licenses" error.
You may see that message if your license is in use on another machine. Please take a look at your licenses page to see if that's the case and if so you may close or complete sign out from Octane to release your licenses. As an option if you don't have access to that machine you use the deactivate button from the website.
If you are using OSX and have coexisting v3 and v2 Octane running, please take a look at this.
