OctaneRender™ Standalone 3.01.1
Wow, that was fast! Thanks for the fixes!abstrax wrote:We just released a quick-fix update (3.01.1) to fix a few major issues. Apologies for the hassle.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Hi Zay,Zay wrote:Shouldn't 2.25 work with a v3 license? My 2.25 is crashing on startup.
v2.25 is working here in both Mac and Win, but Standalone Mac crashes if the slave demon PC v3 is active, while on windows I have no issue with v3 Mac slave.
Could you retry after quitting all the demons slaves?
Did try shutting down the slave but Standalone 2.25 still crashes. It doesn't pass the splash screen before the app crashes.bepeg4d wrote:Hi Zay,
Here it works. Try renaming the default sceneZay wrote:Did try shutting down the slave but Standalone 2.25 still crashes. It doesn't pass the splash screen before the app crashes.bepeg4d wrote:Hi Zay,
%appdata%\OctaneRender\defaults.ocs. If that doesn't help try also renaming the preferences file %appdata%\OctaneRender\preferences_v2. If that fixes the problem, could you send me the renamed files so we can investigate? Thanks.In theory there is no difference between theory and practice. In practice there is. - Yogi Berra
That didn't help. Then I tried to deleted everything in that folder. That gave me the activation window when I ran 2.25. But then it crashed as soon as I hit the "Activate" button.abstrax wrote:Here it works. Try renaming the default scene%appdata%\OctaneRender\defaults.ocs. If that doesn't help try also renaming the preferences file%appdata%\OctaneRender\preferences_v2. If that fixes the problem, could you send me the renamed files so we can investigate? Thanks.
We noticed that the net render slave crash on OSX during the initial launch from the net render daemon. This problem should also occur on the other platforms, but for some reason doesn't. Anyway, to make sure that this issue is fixed we updated the commercial Standalone builds on all platforms (version 3.01.1b). The internal version number did not change to keep current 3.01.1 plugins compatible with these slave versions.
