Bug: Geometry Shells - UI freeze 2+ surfaces in DUF mode
Moderator: BK
DrHemulen
Nope :-/ I normally use manual rebuild of materials, but switching to DUF also worked without issues. Loaded the file and rebuilt the materials. This must be really frustrating.
Does the test scene you uploaded include the shell? I can try playing around with that to reduce the variables.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
linvanchene
DrHemulen wrote:Nope :-/ I normally use manual rebuild of materials, but switching to DUF also worked without issues. Loaded the file and rebuilt the materials. This must be really frustrating.
Thanks a lot for checking again.
Still, at the current time as long as there is not a second user who actually can reproduce this behaviour we can let this rest. I now know several workarounds how to deal with this...
To summarize:
The plugin does not lock up when adding geometry shells when
- the object has just one surface
- the plugin is in AUTO or MAN mode
The plugin locks up when adding geometry shells when
- the object has at least two surfaces
AND
- the plugin is in DUF mode
AND / OR
- a so far unknown 3rd variable / parameter is active
The challenging part is that more than one of those criteria have to be met to encounter the lock up.
If the object just has one surface and DUF mode is activated no lock up happens.
As a last remaining step tomorrow I will uninstall the OcDS plugin, delete all remaining files manually and then check if I can still reproduce the issue.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
When loading geometry shells with multiple surface zones while in DUF material conversion mode a locked state of OcDS is triggered.
That should give me enough info to track the problem down. Thanks.
liquidsnake4ch
Hi, I always have the same problem.
The best way to create the issue is to conform different generation of character and clothing. For exemple G3F and G2F clothing.
DrHemulen
I just had the same issue all of a sudden :( Clean scene with GF3. Octane UI freezes - everything is greyed out - but Daz keeps running. Deleting the shell doesn't help.
I haven't made any changes to DAZ or the Octane plugin since I posted in this thread about not having these issues. No video card updates either.
Return to “DAZ Studio”
