Octane Volume object and fog/haze
kasrafarahani
funk wrote:
Hesekiel2517 wrote:Hey there,
it took me a while to get volumetric Lights. Somewhere i read that you have to connect a scattering-node to the Environment-Medium and set a medium Radius. By doing so i could not get a noise free volume light. Turns out you have to use the volume medium which is not (as far as i know) available in Modo. You have to use a Nodegraph connect it to the Environment-Medium and set up the volume medium there. I hope that helps!
I connected an octane scattering node with the same values as your nodegraph and got the same result (as far as I can tell)
Hi Hesekiel, I just noticed the attached scene file which is super helpful. Thank you!
coilbook
can otoy add normal volume light to their light mesh and lights without using mediums all these cheats like all normal renderers have
kasrafarahani
coilbook wrote:can otoy add normal volume light to their light mesh and lights without using mediums all these cheats like all normal renderers have
That would be the best thing. Odd that it's so technical currently. I still can't make it work, and have given up for now. Just doing it in post
Return to “Foundry Modo”
