Animation Error!!!!!!
Moderator: BK
Veneris
Veneris wrote:
face_off wrote:The following debug build of the plugin adds a message in the Messages area at the bottom of the System tab if the render image fails to save. It will hopefully give us a clue as to why it's not saving. https://render.otoy.com/customerdownloa ... _Win64.exe
Thanks, I've installed (3_0_6_16a) and now the error no longer appears under the same conditions of the scene, the plugin have rendered and saved all the frames correctly. I hope to finish the animation without the error appears again.
I like the way you are attentive, regards.
Okay, this is what happened. I after installing (3_0_6_16a) I did immediately renders the frame 0-342 With 10 s / pix. All renderings were made and saved properly. That was for testing purposes.
Renderings I have to do is 500 s / pix, render the frame 0 to 326 from 342. I got up there because I had me go. I turn off my PC and I left, everything was right.
When I returned, I render the rest of the frame 327 to 342. And the error appeared again. > http://imgbox.com/mVM5qJEe < and > http://imgbox.com/HERHy3o7 <
Later appeared a controller error. > http://imgbox.com/oScvheQw <
Translation: The display driver stopped working and recovered.
The display driver NVIDIA Windows Kernel Mode Driver, Version 364.51 stopped responding and recovered correctly.
I tried again > http://imgbox.com/tCqKz48u <
When I tried again I changed the route where the renderings would be saved, so that the folder was not any files. The error appeared again, the plugin only rendering the same frame again and again. And "Name Prefix" is changed like everything was right. For example: Render_010, Render_011, Render_012, Render_013, Render_014, Render_015 ...
But it was always the same frame Render_010. I can not render the other missing frames to 342.
UPDATE: I restart my PC and I could render without problems. I do not know if the error appears again later in other scenes. We'll see...
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
To be sure you have a robust system, install NVidia driver 358.50, and then install Octane Standalone via the installer .exe (which is set your Nvidia timeouts). Then try rendering the animation.
Veneris
face_off wrote:To be sure you have a robust system, install NVidia driver 358.50, and then install Octane Standalone via the installer .exe (which is set your Nvidia timeouts). Then try rendering the animation.
Hello, I see you returned from vacation.
I continued with animation and I realized that the error always appears when the "Disable DAZ Viewport" checkbox is active. I already checked several times:
Animation Tab
When "Disable DAZ Viewport" is active = Error
When "Disable DAZ Viewport" is not active = no problems.
It is going to be very hard for me to help you unless you provide clear information. Did you install Nvidia drivers 358.50? Did you install Octane Standalone? When you say the animation failed, what did the Message windows in the System tab contain?
Veneris
face_off wrote:It is going to be very hard for me to help you unless you provide clear information. Did you install Nvidia drivers 358.50? Did you install Octane Standalone? When you say the animation failed, what did the Message windows in the System tab contain?
I have 364.51 installed. Do I have to go back?
I have it already installed. What I have to do there?
http://imgbox.com/bkPe1TPy
I have no complaints at the moment. I keep the box "Disable DAZ Viewport" inactive, so I fix the problem. I hope to see the motion blur running. Thank you for your help.
Pls see the red text at viewtopic.php?f=44&t=51808&p=258727#p258727 for the answers to your questions.
Return to “DAZ Studio”
