OctaneRender® for 3ds max® v2.25 - 2.21 [OBSOLETE]
kevinshane
found a bug for this version
if u trying to save a material into LocalDB and then re-import into this version(2.21), u will lose the Mesh UV projection(uv set) from the previous version(1.9), it's gone missing,which means it can't "read" the uv set? anyway,not sure if this is a standalone bug or a 2.21 version bug,hope this could be fixed soon,thanks!
Shane
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
paride4331
Goldisart wrote:Really want to get Phisical support standard camera \ thanks - to work with octane camera is difficult
unpolbo
+1
daniel.reutersward
Hi Jim
A quick question:
If I have tonemapping on and the response curve set to Linear and change the gamma from 1,0 to 2,2 pretty much nothing happens?
In previous version (before the gamma change) I could for instance change the gamma to 3.0 and get a more washed out image.
Now I have to change the gamma to 0.1 to get the same washed out image?
Is this how it should behave? Shouldn´t an increase in gamma give a more washed out image?
anifex3D
Can you add 3ds Max 2017 to the installer? If not how do we manually install with the .exe file? Thanks.
https://anifex.com/ | Win 10 64Bit | i9 - 9920x -128gb ram | 4x RTX Titan 24gb | 3dsMax 2022 Octane Plugin
kilaD
max2012 x64, Stereo rendering dropdowns stuck at Left and Parallel.
Hello
Next version HERE.
Locked
