OctaneRender for Carrara 3.0.0.5 [Test]
Have an issue with previous scenes, but upon further read those are corrupt and can not be rendered in new ver. Was having an issue where as nothing would render. since the log files don't during crashes its a bit hard to provide info here normally. It would be good to have access to the log file in these cases.
[00:13:27.363] Started logging on 26.03.16 19:13:27
[00:13:27.363]
[00:13:27.363] Flag Type Value Prefix Description
[00:13:27.363] ------------------------- ------- ---------- ------------ --------------------------------------------------------------------------------
[00:13:27.363] apiChangeMgr release 0 "apiChngMgr" Logs ApiChangeManager::update().
[00:13:27.363] apiExport release 0 "apiExport" Logs all geometry export operations.
[00:13:27.363] apiNetwork release 0 "apiNetwork" Logs all important calls into ApiNetRenderManager
[00:13:27.363] apiNodeSystem release 0 "apiNodeSys" Logs all write operations in the API node system.
[00:13:27.363] apiProject release 0 "apiProject" Logs all important calls into ApiProjectManager.
[00:13:27.363] apiRender release 0 "apiRender" Logs all important calls into ApiRenderEngine.
[00:13:27.363] cudaProf release 0 "cudaProf" Enables general logging of CUDA profiling.
[00:13:27.363] cudaProfDetail release 0 "cudaProf" Enables logging of single CUDA activity records.
[00:13:27.363] daemon release 0 "network" Not used.
[00:13:27.363] dumpAlembicObjects release 0 "AlembicObjects" Dump data about exported Alembic objects
[00:13:27.363] heartbeat release 0 "network" Enables logging of the network rendering heartbeat.
[00:13:27.363] logAppendToFile release 0 "" If enabled, logging will be to the already existing log file appended
[00:13:27.363] logFlags release 1 "" If enabled, all log flags will be dumped during startup
[00:13:27.363] logFlushTime release 0 "" The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[00:13:27.363] logForceFlush release 0 "" If enabled, every logged line will be flushed
[00:13:27.363] logJuce release 0 "JUCE" If enabled, JUCE logging will go through the logging framework of Octane
[00:13:27.363] logPrefix release 1 "" If enabled, each log line will have a prefix
[00:13:27.363] logTime release 1 "" If enabled, each log line will have a timestamp
[00:13:27.363] logToDebugConsole release 0 "" If enabled, logging will go to the debug console (Windows only)
[00:13:27.363] logToFile release 0 "" If enabled, logging will go to a log file
[00:13:27.363] logToStdout release 0 "" If enabled, logging will go to standard out (when set to 1) or standard error (when set to 2)
[00:13:27.363] netRender release 0 "netRender" General logging of network rendering
[00:13:27.363] stats release 0 "stats" Enables logging of the statistics
[00:13:27.363] subdivider release 0 "subdivider" logs info about the subdivision process
[00:13:27.363]
[00:13:27.363] OctaneRender 3.00 alpha 6 (3000006)
[00:13:27.363]
[00:14:54.770] Scene contents: 9 primitives, 1 cameras, 1 lights, 9 master objects, 96 master shaders
[00:15:03.819] NVAPI initializing...
[00:15:03.819] NVAPI Version: NVidia Complete Version 1.10
[00:15:17.587] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.588] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.595] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.603] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.612] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.636] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.644] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.652] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.660] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.668] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.676] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.684] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.692] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.700] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.708] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.716] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.724] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.732] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.740] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.755] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.771] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.795] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.804] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.811] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.819] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.827] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.836] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.844] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.851] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.859] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.867] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.875] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.883] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.891] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.899] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.907] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.915] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.923] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.932] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.940] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.955] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.956] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.963] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.971] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:17.979] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:27.932] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:27.939] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:27.948] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:27.956] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:15:27.963] ERROR : Could not pick materials, because the geometry has changed and rendering is paused.
[00:16:05.276] ERROR : CUDA error 2 on device 1: The API was unable to allocate enough memory to perform the requested operation.
[00:16:05.277] ERROR : -> failed to allocate device array
[00:16:05.278] Render Failure Callback
[00:13:27.363]
[00:13:27.363]
[00:13:27.363]
There is a text file in the octane extensions folder that contains the log settings. Edit the file and uncomment the logToFile setting.
Edit: You can ignore the 'Could not pick materials' errors, I would suppress them if I could. The last three errors indicate an out of memory condition. Are you rendering volumes?
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Made the change for logging. The scene in question has Gen3 with the free Asian face and worked in previous octane plugin. I did some volume tests earlier in the day but I also rebooted. I have opened other scenes and some of those older ver 2.x scenes work while others don't. Will do more testing.
What? Genesis 3 on Carrara?Tugpsx wrote:Made the change for logging. The scene in question has Gen3 with the free Asian face and worked in previous octane plugin. I did some volume tests earlier in the day but I also rebooted. I have opened other scenes and some of those older ver 2.x scenes work while others don't. Will do more testing.
How did you manage that?
Or do you mean Generation 3, like V3?
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
Win 7-64
Nvidia GTX 760
Genesis 3. She works really well in Carrara.
@Sighman, the sliders on the Render Target pop-out are a bit sensitive. A small click produces large change in most cases. Can we get numerical input.
@Tugpsx: Great images!
But how did you do it? Either this technique crossed my way silently or you found a way the whole community is seeking for.
My Rig:
Win 7-64
Nvidia GTX 760
Win 7-64
Nvidia GTX 760
