OctaneRender® for 3ds max® v2.25 - 2.19 [OBSOLETE]
oguzbir
JimStar wrote:I already thought about it as the only way to hack this problem.
During the scene translation I can look at the angle between vertical and current camera UP-vector and if it is say less than 1 degree - change the placement of camera loaded into Octane render core to vertical.
But in this case - you may see in some cases the inconsistency in camera tilt between viewport and rendered image if "Perspective correction" is on...
I see your point man. But I guess it's better than nothing. Shame on Autodesk.
Anyway thanks.
My Portfolio
OK, let's try it.
Will implement it in next version.
Next version HERE.
Locked
