New Desktop Build - Advice Requested
Moderator: BK
swipswap
Kotoboy wrote:Video Card: PALIT GeForce GTX 970 4GB Gddr5
Be aware that the GTX 970 has only 3.5GB of VRAM available to Octane. 512MB of that VRAM is segregated, slow and not even acknowledged by Octane. I own one, so unfortunately I know this from experience.
This issue brought up 7 class action lawsuits against NVIDIA. I would recommend going with a 980 or a 980ti if you can afford it.
Best of luck.
Kotoboy
Thank you Spectralis, I totally agree with your advice, but I don't have the time to built my computer on my own :( and I don't have the money if something goes wrong when I put together the single parts.
K.
i5 CPU - 750 2.67 GHz
RAM: 8 Gb
Windows 7 (64 bit)
Graphic card: NVIDIA GeForce GTX 760
Octane 2.0 DazStudio + Standalone 2.0 + Daz Studio 4.7
Octane 1.5 Poser + Standalone 2.0 + Poser Pro 2012
Kotoboy
swipswap wrote:Be aware that the GTX 970 has only 3.5GB of VRAM available to Octane. 512MB of that VRAM is segregated, slow and not even acknowledged by Octane. I own one, so unfortunately I know this from experience.
OMG Thank you ;)
RAM: 8 Gb
Windows 7 (64 bit)
Kotoboy
So the GTX 970 is useless compared to my actual GTX 760? The GTX 980 is much more expensive (and I don't know if I can afford it) but could be a solution?
And a last thing: If I install the 760 + 970, this setting it will improve my render?
Thank you
K.
RAM: 8 Gb
Windows 7 (64 bit)
Hydra
Kotoboy wrote:So the GTX 970 is useless compared to my actual GTX 760? The GTX 980 is much more expensive (and I don't know if I can afford it) but could be a solution?
Thank you
K.
Ah no. You'll do fine with the GTX 970. If you do large complex scenes, then it may be an issue but otherwise the 970 is just fine. You can use out of core textures if you get tight for memory, the impact is only like 10% of your render performance. I've already run 8.5GB renders using my 4GB cards. Anyways, with Octane you have a huge amount of control over memory usage.
Everything I've heard about mixing and matching cards is that it can be problematic. In practice I use my secondary GPU when using Daz, and I only turn on both cards for final render. I can play video games while rendering or goofing around this way.
FYI, I upgraded by my 970s to 980s over this issue, but it was probably unnecessary.
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
Kotoboy
Thank you Hydra ;)
RAM: 8 Gb
Windows 7 (64 bit)
Return to “DAZ Studio”
