The idea of re-authoring is ludicrous, do none of the auto-smooth & group by material options work?Chris wrote:Export to DWG from Revit works fine imo.
If you don't plan to use any of your clients furniture/etc you can purge/delete it out of the Revit model easily from within Revit: can be a different of about 1/3 smaller (3x Larger) between a cleanly build Revit model and a dirty (Read: Lazy) one.. How big is the revit model, L x W x H of the building (any units) and in MB on disk???
In our office we use RVT->DWG->MAX or most recently have been trying the new Revit Link; which I understood allows a live link to the Revit file from within max - as the production team make changes to the model it is updated in max and groups/etc are preserved in MAX (apparently saves some time on big projects once all the Revit->Max translations are setup ?? not my field): I understand very little about how it works.
For a single snapshot (ie client will never send you any updates) DWG or OBJ might be better (After you've cleaned the Revit Model)
