OctaneRender® for Maya® 2.23.2 - 7.9 Win [OBSOLETE]
Refracty
I'll check it - it looks like some regression bug, as the support of it was already implemented a long time ago... Thanks for report.
zurakan
hi again
i found another bug
render setting Create layer Override is still work
when i set Create layer Override in render layer maya render View it OK but try render batch it not work
thank so much
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
blackshore
I have verified that the maya plugins 7.4>7.9 do not support out-of-core feature even if the checkbox is there.
The function works perfectly when saved out as octane file and rendered in standalone.
Will this be fixed?
Jolbertoquini
Hi Jim
what about the version 2.24 we have a new version already 2.24.1 is some bugs fixed. Also exr options.
Cheers
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Refracty
When using Transform nodes for HDR Environments only one rotation value is working.
This applies to all transform nodes like FullTransform, 3D- and 2D-Transforms.
In Octane Standalone I can rotate the HDR Sphere freely.
Any ideas to make this working in Maya?
Another question is about the motion blur.
The motion blur only shows up if I set up an image sequence.
But when I render the actual frame (via batch or the render button). Motion Blur does not show up.
And it would be great to have a mb option for the IPR aswell to see whats going on this the MB in realtime.
abeoctane
Please, please Jim, if possible, implement a slider bar to the HDRis transformation nodes, like rotation and position, other software plugins have it, it is very slow to modify the rotation and position of the HDRis by typing the number, I think its a lot better to have a slider bar, thank you very much.
Refracty
Hi JimStar,
any infos about the broken Transform nodes in Maya (y,z rotation not working)?
Is this a bug or a known limitation?
Next version HERE.
Locked
Return to “Autodesk Maya”
