OctaneRender™ 2.2 for Houdini™ build 2.24.0.0
Angelos
Yes. Now it works!
juanjgon
Great!!! ... it is nice to know that the plugin can work with external render controllers like Deadline with little changes in the scripts ;)
Angelos
I tried to render simple animation through Deadline but the Octane save only one png image each frame. It each time overwrite every frame to an one .png. but I need a sequence of png's.
juanjgon
Weird issue, so do you get all the frame files saved as "sphere3.Octane_ROP1.0001.png"? ... if you render the scene from the ROP node, not using deadline, all works fine?
It can be again a problem in the Deadline's render script, but I can't figure what could be problem.
frostfx
same problem here
3xGTX Titan + GTX 770 | i7-4820 | 64GB RAM
3D Animation and Visual Effects http://frostfx.ee/
juanjgon
frostfx wrote:same problem here
And if you render the scene from the ROP node, not using Deadline, all works fine?
frostfx
yes, then it works fine
juanjgon
Really weird issue. I can't see anything wrong in the Deadline script posted earlier in this thread.
I think that you should ask about this issue to the Deadline developers to know their opinion about where could be the problem. I can talk with them without problem if needed, but really I am not an expert in Deadline, and I don't know it's internal architecture to know what could be the source of the problem.
