I tried updating to the new v7, but that was even worse! I downgraded to 6.5.51, and that seemed to work better.
I will try and update my drivers and CUDA driver to the latest and see if that helps...
Crash on changing current frame
- johnhorizonvp
May have solved it! ...maybe... I installed CUDA 6.5.45, and tried having the application window on the
same monitor as the IPR and it seems to be fixed! I'll do some more tests...
I think that now I get also a crash here, hard to reproduce, but it crash.
I am also updating the CUDA drivers to the last version (7.0.52) to see what happens.
At least if I can reproduce it here I have a chance to fix it
Thanks, I will also try the plugin with this CUDA version.johnhorizonvp wrote:May have solved it! ...maybe... I installed CUDA 6.5.45, and tried having the application window on the
- johnhorizonvp
Damn! It still crashes, but seems more stable
- johnhorizonvp
if I pan the camera inside the IPR, it also crashes
- johnhorizonvp
OK Thank you. Maybe the IPR camera shouldn't update until the mouse button is released.
I have a new build of the OSX plugin with some new code in the IPR OpenGL window. Here it seems to work fine, without crashes so far. Can you please test it?
You should see in the "about" window that this version is compiled on Jul 9 2015
https://www.dropbox.com/s/prod4ddv271a4 ... n.zip?dl=0
