Hey Rappet.
I had a similar problem with psu.
With a 860w corsair psu. Stopped working, Board was Asus rampage IV
working with 2 gpus 5- disk drives.
It turned out to be either things
I didn't connect the pcie power to the board giving extra power when needed.
I kinda sorted out my problem but then it reoccured.
Clicking power button on my cosmos II case sometime worked sometimes not.
Some times I reset bios. And powering the button worked.
I even changed the mainboard battery where I heard some problems about it.
The problem continued.
I was pissed with this and purchased Cosair 1500axi psu.
All problems went away.
But I did check the PSU with other PC. I worked flawlessly as before.
Maybe your psu cant handle it. after some changes you forgot doing/adding to the system.
An overclock maybe?
PSU dead or start button fails
My Portfolio
You could recheck the connections to the mother board.
Connectors are the bane of all known existence. Its always disturbing when a problem appears and goes away without explanation. In fact I'd take the time to locate a replacement switch in case it happens again. Power supply failures are annoying, but easy to replace (as long as there's no fire.)
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
